I try to add a tabulate table into my journal for reporting. But i been stuck in JSL with error and the tabulate table is not able to add into journal. Please advise what am i missing?
Clear Symbols();
Clear Log();
Close All( Data Tables, NoSave );
Close All( Journals, NoSave );
//Journal
nw = New Window( "Reports",
<<Journal,
hlb = H List Box(
lub = Lineup Box( N Col( 1 ) )
lub << Append ( sb = Spacer Box( size (10, 500), color ("White") ) );
lub << Append( tb = Text Box( "VENUS SMIC CYCLING REPORT " || Short Date( Today() ) ));
tb << Set Font Size( 20 ) << Set Font Style( "Bold" ) << Justify Text( "Center" );
tb << set width(1500) << set wrap((1500));
lub << Append( Page Break Box() );
dt_source = Open( "TEST.jmp" );
dt_source:hardbin << Data Type( Character );
dt_source << New Column( "FFT", "Character", "Norminal",
Formula(
If( :hardbin == 1,
"Pass;1",
Char( :Name( "failtest_name,0,0" ) || ";" || Char( :Name( "failtest_number,0,0" ) ) )
obj_table = dt_source << Tabulate(
Add Table(
Column Table( Grouping Columns( :Wafer ) ),
Row Table(
Grouping Columns( :hardbin, :BinName, :FFT ),
Statistics( Name( "% of Total" ) )
lub << Append( obj_table ); // where i got the error
