Jackie_
Adding Progress bar in the script
Hello ,
I have a data table with a million rows and am trying to add a progress bar window in the script. I found this threat (Progress bar) from Craige useful. I am new to this, so I am still trying to understand where to add the code to indicate the progress. Any suggestions?
Code for a Progress bar from @Craige_Hales
progressBarWidth = 500;
progressUpdatesSeconds = 1 / 4; // 1/2 sec updates -> 1300ips,  1/30 -> 1000ips (1/4 compromise speed vs appearance)
cancel = 0; // clear the cancel flag
New Window( "Progressbar demo", //
	Show Menu( 0 ),
	show toolbars( 0 ),
	V List Box( //
		cats = Text Box( "" ), // output from the work function
		t = Text Box( "", <<setwrap( 500 ) ), // status of the progressbar
		H List Box( // Duct tape has a light side and a dark side. So does the progressbar.
			left = Spacer Box( size( 0, 10 ), color( "light green" ) ), //
			right = Spacer Box( size( progressBarWidth, 10 ), color( "dark green" ) ), //
			<<padding( 5, 5, 5, 5 ), // gray wrapper
			<<backgroundcolor( "dark gray" ) //
		cancelButton = Button Box( "Cancel", cancel = 1 ) // sets the cancel flag
Wait( 0 ); // allow the window to open, otherwise the updates are not visible
// progressbar variables
startMicroSeconds = HP Time();
workCalls = 0;
recentUpdateMicroSeconds = HP Time();
runSeconds = (recentUpdateMicroSeconds - startMicroSeconds) / 1e6; // so the loop can start
limitSeconds = 10; // time to run the demo
updateProgress = Function( {fractionComplete},
	leftsize = Round( progressBarWidth * fractionComplete );
	rightsize = progressBarWidth - leftsize;
	left << width( leftsize );
	right << width( rightsize );
	t << settext(
		Eval Insert(
			"^workCalls^ iterations in ^char(runSeconds,6,3)^ seconds -> ^workCalls/runSeconds^ ips"
	t << updatewindow; // this works without the wait
totalCats = 0;
dowork = Function( {},
	x = "";
	For( i = 1, i <= 1000, i += 1, x = x || "." );
	totalCats += 1000;
	cats << settext( Eval Insert( "total concatenations=^totalCats^" ) );
While( runSeconds < limitSeconds & !cancel, // change this to represent the work you are doing
	// do some work, simulated by concatenating strings...
	dowork();
	// update the progressbar
	workCalls += 1;
	nowMicroSeconds = HP Time();
	// how often does it need to update on the screen?
	If( (nowMicroSeconds - recentUpdateMicroSeconds) / 1e6 > progressUpdatesSeconds,
		// in this example I'm using a fixed time duration of "limitSeconds" to represent the
		// amount of work to be done. And "runSeconds" to represent the amount of work done so far.
		// Usually you'll have something other than time: number of rows in a table perhaps, or
		// number of categories to make reports for. As long as you know how many total and how
		// many completed, you can compute this fraction...
		updateProgress( runSeconds / limitSeconds );  // change this to represent the fraction of work finished
		recentUpdateMicroSeconds = nowMicroSeconds;
		Wait( 0 ); // this wait is needed to let the cancel button work
	runSeconds = (nowMicroSeconds - startMicroSeconds) / 1e6;
If( cancel, // test the cancel flag
	Beep(); // audio flag
	left << color( "dark red" ); // visual flag something is awry
	right << color( "red" );
	updateProgress( 1.0 ); // people like to see the bar go to 100%
cancelButton << setbuttonname( "Close" ); // visual flag the button function is changed
cancelButton << setscript( (cancelButton << closewindow) ); // and what to do if the button is pressed
JSL to generate plots
dt = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
List1 = {"NPN1", "PNP1", "PNP2", "NPN2", "PNP3", "IVP1"};
List2 = {"PNP4", "NPN3", "IVP2", "NPN4", "SIT1"};
List3 = {"INM1", "INM2", "VPM1", "VPM2", "VPM3"};
List4 = {"SNM1", "SPM1", "NPN5", "EP2", "ZD6"};
var expr1 = Expr( Variables() );
For( c = 1, c <= N Items( List1 ), c++,
	x expr1 = Expr(
		X( Position( 1 ), Combine( "Parallel Merged" ) )
	Insert Into( x expr1, List1[c], 1 );
	Insert Into( var expr1, Name Expr( x expr1 ) );
var expr2 = Expr( Variables() );
For( c = 1, c <= N Items( List2 ), c++,
	x expr2 = Expr(
	Insert Into( x expr2, List2[c], 1 );
	Insert Into( var expr2, Name Expr( x expr2 ) );
var expr3 = Expr( Variables() );
For( c = 1, c <= N Items( List3 ), c++,
	x expr3 = Expr(
	Insert Into( x expr3, List3[c], 1 );
	Insert Into( var expr3, Name Expr( x expr3 ) );
var expr4 = Expr( Variables() );
For( c = 1, c <= N Items( List4 ), c++,
	x expr4 = Expr(
	Insert Into( x expr4, List4[c], 1 );
	Insert Into( var expr4, Name Expr( x expr4 ) );
lists = {"List1", "List2", "List3", "List4"};
var = {};
gbv = {};
For( i = 1, i <= 4, i++,
	Insert Into( var, Name Expr( Eval( Parse( "var expr" || Char( i ) ) ) ) );
	Insert Into( gbv, Parse( "vvv" || Char( i ) ) );
nw = New Window( "Plots",
	Show Menu( 0 ),
	show toolbars( 0 ),
	H List Box(
		Check Box(
			{"Summary"},
			<<Set Function(
				Function( {self},
					sel = self << get selected();
					If( N Items( sel ) > 0,
						For( i = 1, i <= N Items( lists ), i++,
							If( N Items( Eval( Parse( lists[i] ) ) ) > 0,
								nw[lists[i], Outline Box( 1 )] << append(
									V Scroll Box(
										size( 580 ),
										Border Box( Left( 5 ), Right( 5 ), Top( 5 ), Bottom( 5 ), Sides( 15 ),
											Tabulate(
												Show Control Panel( 0 ),
												Set Format( Uniform Format( 10, 2 ) ),
												Add Table(
													Column Table( Statistics( Mean, Std Dev ) ),
													Row Table(
														Analysis Columns(
													Dispatch( {}, "Tabulate", OutlineBox, {Set Title( "Summary Stats" )} )
								) << Visibility( "Visible" );
					/// Xpath syntax
	nw << XPath( "//Outlinebox[@helpKey = 'Summary Stats']" ) << delete;
		V List Box( tb = Tab Box() )
	tb << Add(
		lists[i],
		V List Box(
			H List Box(
				Eval(
					Eval Expr(
						gb = dt << Graph Builder(
							Size( 1117, 781 ),
							Expr( Name Expr( var[i] ) ),
							Elements(
								Histogram(
									X( 1 ),
									X( 2 ),
									X( 3 ),
									X( 4 ),
									X( 5 ),
									X( 6 ),
									X( 7 ),
									X( 8 ),
									X( 9 ),
									X( 10 ),
									X( 11 ),
									X( 12 ),
									X( 13 ),
									X( 14 ),
									X( 15 ),
									X( 16 ),
									Legend( 2 ),
								Box Plot(
									X( 1 ),
									X( 2 ),
									X( 3 ),
									X( 4 ),
									X( 5 ),
									X( 6 ),
									X( 7 ),
									X( 8 ),
									X( 9 ),
									X( 10 ),
									X( 11 ),
									X( 12 ),
									X( 13 ),
									X( 14 ),
									X( 15 ),
									X( 16 ),
									Legend( 3 ),
									Outliers( 0 )
				sumsta = Outline Box(
					lists[i],
					<<visibility( "Collapse" )
SDF1
Re: Adding Progress bar in the script
Hi @Jackie_ ,
  A typical place to put something like a progress bar update would be at the start (or end) of an iterative loop, like a For() loop or a While() loop. So that at the start of each iteration, the progress window is updated to reflect the changes. You can find a solution with some description and discussion here.
Hope this helps!,
DS
Jackie_
Thanks.
