drblove
Adding Math symbol with JSL Journal Text Box
I am thinking that this is probably very easy, just in a text box, I would like to add a symbol like a capital sigma, or a summation symbol.  I am trying to write an equation in a text box, is this just an html trick?
Thank yu in advance,
Brad
Re: Adding Math symbol with JSL Journal Text Box
Most font families include a number of symbols, which can be used in JMP by specifying their unicode character values.  The advantage of not changing fonts is that you can use all of the regular characters as well as symbols.
new window("Sample",<<journal,
	HLB = H List Box(
		tb1 = Text Box("\!U01A9x\!U00B2")
tb1<<set font style("Bold")<<set font size(72);
This should work anywhere in JMP that you can set a string, even if the font cannot be changed.  You can look up Unicode values at http://www.unicode.org/charts/, and there are also font viewers available that will show you the characters that are in the fonts that you have on your machine.  If you stick to common characters then your code will probably be fairly portable, but it's good to know that if you are using less common characters then they may exist in one font but not in another.
You can add markup commands to a text box, and specify, << markup(1) as a second parameter in the text box, You could also try using the function
   Expr as Picture(........)
where you can place a formula into the passing element and it will draw a picture.  I have not figured out how to specify a Sigma using this method
or you can do something more like:
	HLB = H List Box(
		tb1 = Text Box("S")
tb1<<font("Symbol")<<set font style("Bold")<<set font size(72)
	HLB = H List Box(
John_Powell_JMP
Unicode characters also often work in HTML while you can't count on symbol fonts being available in web browsers.
Here's Dan's example in JMP, then saved as HTML and viewed in Internet Explorer.
Unicode characters in JMP and a web browser(Internet Explorer)Unicode characters in JMP and a web browser(Internet Explorer)
