sibanibisoyi
Adding Data Labels in a graph using scripting
I need help in adding the Data Labels in a graph using Scripting. I want to display always the data value of the recent row.
I marked the column as Label, and I also marked the row as label. But I don't know how can I write the script for the same.
Re: Adding Data Labels in a graph using scripting
Below is an example of how to accomplish what you want.  You need to get familiar with the Scripting Index.  It will provide you with the documentation and examples of how to do things such as you have asked.
     Help==>Scripting Index
dt = Current Data Table();
dt:Column 1 << Set labelled;
dt << select where( :Pressure == 60 ) << label;
