Hi @BryanG ,
I had not come across the idea of axial points for mixture designs. From a quick search I found that an axial point is a mixture that is half-way between the centre-point and a vertex of the mixture space.
I am not aware of anyone recommending an approach of augmenting simplex lattice or simplex centroid designs with axial points as part of sequential experimentation. I don't think it would be a bad idea necessarily. But just not the best way to do things.
The recommended approach in JMP is optimal augmentation. That is, JMP will find the additional runs that are optimal to test the model that you have defined. You define the factors, factor ranges, model to estimate, and number of additional runs. Then JMP gives you the optimal additional runs.
Axial run augmentation is an option for designs with continuous (not mixture) factors. But it is really there for people that were taught the conventional (pre-computer) DOE methods.
As a workaround, you could create the ABCD design (DOE > Classical > Mixture Design) as this will contain the axial points. You can then copy them and add them to your existing design.
I hope this all helps,
Phil
