ravij
Add variable in Graph builder
I have data table with multiple columns and rows
I want to loop through each column and add it to graph builder on x -axis
This is my simple script
dt = Open( filepath );
all_cols = dt << Get Column Names( "String" );
cols_to_plot={};
For Each ({col}, all_cols,
           If(col == "A" || col == "B",,
                        Insert into (cols_to_plot, col);
graph = dt << Graph Builder();
For Each ({col},cols_to_plot,
           graph << Add Variable ("X", Column(dt, col)); // Also tried  graph << Add Variable (X, Column(dt, col));
This script is always giving me below error
argument value is invalid in access or evaluation of 'Add Variable' , Bad Argument( "X" ), Add Variable( "X", Column( dt, col ) ) /*###*/at line 600
Just as a check if I run below script it works fine, but I want to plot it for ~1000 columns
Variables(X(cols_to_plot[1]),X(cols_to_plot[2]),X(cols_to_plot[3]));
what am I missing here, appreciate your help
Edit (jthi): added jsl formatting
Re: Add variable in Graph builder
As you have so many columns, I would most likely build the Graph Builder expression instead of adding columns one by one. Create the graph manually, copy the script to see how it has been built and then replicate it using JSL. Below is one example
JMP created script
Graph Builder(
	Size(528, 458),
	Show Control Panel(0),
	Variables(
		X(:"0.642539"n, Combine("Parallel Merged")),
		X(:"0.645736349"n, Position(1), Combine("Parallel Merged")),
		X(:"0.648933698"n, Position(1), Combine("Parallel Merged")),
		X(:"0.652131047"n, Position(1), Combine("Parallel Merged")),
		X(:"0.655328396"n, Position(1), Combine("Parallel Merged")),
		X(:"0.658525745"n, Position(1), Combine("Parallel Merged")),
		X(:"0.661723094"n, Position(1), Combine("Parallel Merged")),
		X(:"0.664920443"n, Position(1), Combine("Parallel Merged")),
		X(:"0.668117792"n, Position(1), Combine("Parallel Merged")),
		X(:"0.671315141"n, Position(1), Combine("Parallel Merged")),
		X(:"0.67451249"n, Position(1), Combine("Parallel Merged")),
		X(:"0.677709839"n, Position(1), Combine("Parallel Merged")),
		X(:"0.680907188"n, Position(1), Combine("Parallel Merged")),
		X(:"0.684104537"n, Position(1), Combine("Parallel Merged")),
		X(:"0.687301886"n, Position(1), Combine("Parallel Merged")),
		X(:"0.690499235"n, Position(1), Combine("Parallel Merged"))
	Elements(Points(X(1), X(2), X(3), X(4), X(5), X(6), X(7), X(8), X(9), X(10), X(11), X(12), X(13), X(14), X(15), X(16), Legend(4)))
To create this with JSL you could do something like this
dt = Open("$SAMPLE_DATA/Functional Data/NMR DoE.jmp");
nrmcols = dt << get column group("NMR Spectra");
colnames = Transform Each({col}, nrmcols,
	AsColumn(dt, col) << get name;
colnames = colnames[1::20];
var_expr = Expr(Variables());
points_expr = Expr(Points());
For Each({colname, idx}, colnames,
	x_expr = EvalExpr(X(Expr(NameExpr(AsColumn(dt, colname))), Position(1), Combine("Parallel Merged")));
	point_expr = EvalExpr(X(Expr(idx)));
	Insert Into(var_expr, Name Expr(x_expr));
	Insert Into(points_expr, Name Expr(point_expr));
gb = Eval(Substitute(
	Expr(dt << Graph Builder(
		Size(528, 458),
		_var_,
		Elements(_points_)
	Expr(_var_), Name Expr(var_expr),
	Expr(_points_), Name Expr(points_expr)
Write();
8 REPLIES 8
Not exactly sure what type of plot you are going for, but one example would be something like this
cols_to_plot = {"age", "sex"};
	Eval(EvalExpr(
		graph << Add Variable({Expr(NameExpr(AsColumn(dt, col))), Role("X")});
Check correct syntax from Scripting Index for << Add Variable and use expression evaluation to get column reference in correct format
(Depending on your final plot, you might want to go other route where you build the whole graph builder expression)
ravij
I tried this method and also tried
For Each ({col}, cols_to_plot,
col_ref = Column(dt, col);
graph << Add variable (col_ref, Role("X"));
In both cases my jsl hangs, I only have 1000 columns and 500 rows in my data table
is it the efficient way of doing it, or is there any better way to plot all columns of the table on X axis at once, if I try the same on GUI it is much faster
What type of plot are you trying to create?
ravij
I am trying to create a Simple scatter plot, with all columns on X-axis serially
Something as below
JMP created script
Graph Builder(
	Size(528, 458),
	Variables(
		Size(528, 458),
		_var_,
		Elements(_points_)
Write();
ravij
This works perfectly, Thanks for the help
ravij
I have a follow up problem with these graphs I plotted, I am not able to save them in any format I tried .jmpreport .jrp etc, as I don't want to save graph in static png, jpg formates, I want to save interactive graph with data embedded in it
nw = New Window("printing window",
    Show Window(1),
    Size(528, 458),
    _var_,
    Elements(_points_)
reportpath = ::my_dir_path||"/metadata/"||metaTestfile; newWindow<< Save(reportpath);
Also tried
				Show Window(1),
				Size(528, 458),
				_var_,
				Elements(_points_)
gb << Show Window;
newWindow = Window (gb);
newWindow<< Save(reportpath );
The script doesn't throw any error in any case but also not saving the graph
Scripting Index usually has the answers for scripting (<< Save Window Report)
		Size(528, 458),
		_var_,
		Elements(_points_)
gb << Save Window Report("$DOWNLOADS/test.jrp", embed data(1));
// demo purposes
Close(dt, no save);
wait(1);
Open("$DOWNLOADS/test.jrp");
Write();
