UserID16644
Add values on same column
How can I add the N rows and store the sum on the next column?
Re: Add values on same column
Create new column with a formula
Col Sum(:N Rows)
You can also right click on N Rows and use interactive formula builder
which will create same formula
Col Sum(:N Rows)
Please see Jarmo's     @jthi  response for the solution.  I also suggest that you take the time to read through the Discovering JMP and Using JMP documents to add to your efficiency in using JMP.  One of the JMP features that is covered is the Formula Editor, which interactively presents all most all of the functions that can be used in the calculation of new formula columns.
