RVhydrA
Add values into X number of lag rows
I have a continuous dataset with measurements every 5 minutes over many years. Certain time periods have been designated and assigned and ID# (e.g. 1, 2, 3,... 500). For each of these periods of time that received an ID I want to extend the column ID backwards in time for 4 hours (ie 48 rows back). So for example If the period categorized as ID# 200 starts on 1/1/2020 at 12:00PM, then I currently have empty cells in the previous 48 rows leading up to that timestamp. I want to fill those rows (1/1/2020 8:00AM - 1/1/2020 11:55AM) with the ID value of 200. I figured there is some sort of indexing (row i - lag row i-48) way to do this but not sure how to execute that. There is a very very clunky way to execute this using a ton of if,then statements but i'm trying to avoid that because i'd need 48 of those to make this work and the formula would be ridiculous.
Re: Add values into X number of lag rows
Here is a simple script that when it finds an ID#, it populates the previous 48 rows with the current value of ID#
// Create a table with ID# every 49 rows
dt = New Table( "Example",
	add rows( 490 ),
	New Column( "ID#",
		character,
		formula(
			x = "";
			If( Mod( Row(), 49 ) == 0,
				x = Char( Row() / 49 * 100 )
			x;
dt << rerun formulas;
dt:ID# << delete formula;
// Observe the data table for 5 seconds
Wait( 5 );
// Pass across the data table, and when an ID# is found,
// Populate the previous 48 columns
For( i = 49, i <= N Rows( dt ), i++,
	If( :ID#[i] != "",
		:ID#[(i - 48) :: (i - 1) ] = :ID#[i]
I think it possible to do it with Lag() but I went this time without by using rounding to closest 48. Maybe something like this would work:
dt = New Table("Untitled",
	Add Rows(192),
	Compress File When Saved(1),
	New Column("time",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values(
			[1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20,
			21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38,
			39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56,
			57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74,
			75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92,
			93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108,
			109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122,
			123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136,
			137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150,
			151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164,
			165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178,
			179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192]
	New Column("id",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values(
			., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., 1,
			., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., 2,
			., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., ., 3]
		Set Display Width(47)
tempcol = dt << New column("formula",
	Formula(
		If(IsMissing(:id),
			:id[Ceiling(Row()/48)*48], //Ceiling rounding to closest 48 and get value from :id
			:id
	add rows( 490 ),
	New Column( "ID#",
		character,
		formula(
			x = "";
			x;
Wait( 5 );
	If( :ID#[i] != "",
