Add prefix column names (no scripting)
I am using JMP 19.1.0 with this fantastic function of "Columns manager". I was wondering if there is a way to add prefix to our columns names for all of them at once? I seem to not find any option in the menus that performs this automatically.
Francesc B (Stability Scientist)
Re: Add prefix column names (no scripting)
Use Recode Column Names
Though I'm not exactly sure if there are better options than utilizing regex (without some scripting)
Thanks for your answer Jarmo! Do you know by chance any easy webpage for "dummies" in regex like me, to be able to start using them?? Thanks in advance
In this case I did just know I could use Recode's Replace String with Regex to do what you asked.
In general, https://regex101.com/ is the one I use when testing regex, just be careful with company data as always.
LLMs are also quite good with regex, so you can try asking from them.
