tom_abramov
Add multiple independent Y's to Graph Builder by one drag and drop
For creating several independent Y axeses, I drag one above one.
If I have 20 parameters, it will take a while.
Is there some way (without script) to add all 20 by one drag and drop?
Thanks
Re: Add multiple independent Y's to Graph Builder by one drag and drop
Pressing and holding down Shift-key at specific location seems to work (I'm using JMP 15.2):
  1. Select all the columns you need in the Graph Builder
  2. Sstart dragging them to the Y-axis
  3. Before you are on top of Y-axis press Shift-key down
  4. Check if the Y-axis looks correct and if it does, release mouse1 (and shift)
tom_abramov
Thanks! As always, simple
