Add information to point in graph
Hi all,
(The following text is related to the attached graph) I would like to see in the interactive HTML file (the way I save the graph) the "Carrier ID" of each single point in the graph when I move the mouse on it. Is there any possibility to show this information although the colunm in not part of the chart itselve?
I was thinking about to add the "Carrier ID" as a text to the "Grommet Height [mm]" so it is visible in the graph when I move the mouse to a point but I was not able to find a way to get this done...
Can anybody help me out here?
Thanks.
Regards,
Daniel
GM
GM
Re: Add information to point in graph
Hi Daniel, before you save the graph as interactive html, highlight the column(s) you want to display when you hover over the point and then right click with your mouse the column name section of the data table and the 9th or so option in the dialog is "Label/Unlabel". Select that and you will see a label icon appear in the Columns list next to the columns you have selected to have a label.  Then when you save as interactive html, your carrier id will be displayed when you move the mouse over the point.
Hope this helps.
GM
GM
Hope this helps.
