Add final result column for different test conditions.
Feb 21, 2025 03:45 PM(1172 views)
I did asked similar question earlier but that, that solution doesn't work when I have different number of test station for a same run. if run 1 has 2 tests and run 2 has 3 tests than this solution doesn't work.
