rshehadah
Add double quotes to a string
How can I add double quotes using formula?
"" || :Code || "" || ":" || "" || :Description || "" || ","
I try doing "", but it does not work.
Thank you,
Rami
Re: Add double quotes to a string
\! is the escape character sequence in JMP.....look in the Scripting Guide for further information on using the escape character sequence. Therefore, you need to specify
within a quote string to specify an embedded quote
