Add column based on a user input.
I made a script which gives a pop box to enter suspected wafer list. Than it will add a column to the table with using If loop. This script is working fine when Wafer data type is Character but it doesn't work with Numerical type data type. How can I fix this?
dt = Current Data Table(); // Get the current data table
nw = New Window("Enter Shop order",
	<<Modal,
	<<Return Result,
	V List Box(
		Text Box(" "),
		variablebox = Text Edit Box("", <<Set N Lines(30), <<Set Width(150)),
		Spacer Box(Size(0, 10)),
		Button Box("OK"),
		Button Box("Cancel")
unique = Collapse Whitespace(nw["variablebox"]);
sql_in = Associative Array(Words(unique, ", ")) << get keys;
myValueList = Concat Items(sql_in, ", ");
// Define a list of values to check against
//myValueList = {"1", "2"};
// Create a new column with a formula using the If statement
dt << New Column("Suspected",
	Formula(
		If(Contains(myValueList, :Name("Wafer")),
			"Yes",
			"No"
Re: Add column based on a user input.
Most likely easiest option is to wrap your :Wafer column in the formula with Char()
dt << New Column("Suspected", Formula(If(Contains(myValueList, Char(:Wafer)), "Yes", "No")));
