View Original Published Thread
Add a csv to a JMP Data Table
mochar
Hi all. I've looked around to see if there is a script that adds/imports a csv file while still keeping the old data.
My objective is to have a master JMP file. Then everytime I test a different device/different date, I would like it to be added to the master JMP Data table without overwriting it. I've seen code that meshes all csv files in a folder, but I would like it for just one csv file at a time. (All files have the same columns)
Re: Add a csv to a JMP Data Table
You are thinking too hard.  This is a simple straight forward task
names default to here(1);
dt = Open("<path to the master jmp file>);
dtNew = Open("<path to the new csv file>);
dt << concatenate( dtNew, append to first table(1));
dt << save(<path to the master jmp file>);
