Franck_R
Add a configuration setting when connecting a database (postgresql) with JMP in the same CustomSQL() instruction
I would like to speed up some SQL queries with special configuration values for my postgresql database.
For example: SET random_page_cost = 1
How can I do this in JMP?
Indeed if I create a CustomSQL query
Then a another one with a classic SELECT FROM... it doesn't work because the value "random_page_cost" seems to be reset to its default value on the second database connection.
Is it possible to chain 2 instructions in a same CustomSQL() statement in JMP? How?
Thanks!
ih
Super User (Alumni) ih
Re: Add a configuration setting when connecting a database (postgresql) with JMP in the same CustomSQL() instruction
Could you combine them in a single string and run them both at once?
sql = "SET random_page_cost = 1; SELECT FROM...;"
