BethZ18
Add Variability Summary Report to All Open Variability Graphs
Hi All,
I have a question regarding variability summary report. By default, my JMP does not include the table in the variability charts. However, if I want to add the report to all the charts, instead of click on each one of them, is there a faster way to change the default setting or something?
Re: Add Variability Summary Report to All Open Variability Graphs
A standard capability in JMP is to press the CNTL key and to hold it while you make your selections for one graph or analysis, and JMP will repeat the selection across all analyses in the output display.  So all you have to do  is to hold the CNTL key down as you select the Variability Summary Report and the report will be displayed for all Variability Chart Columns.
You can also set the Preferences for the Variability Chart Platform, so that the Variability Summary Chart will be displayed by default.  Go to
     File==>Preferences==>Platforms==>Variability Chart
And select the checkbox for Variability Summary Chart
BethZ18
Thank you very much!
