Neo
Neo
Add Ref Line () not working if axes names are supplied from outside.
The first case works fine but the second case where the axes names are supplied from outside does not work, where am I going wrong?
Graph Builder(
	Size( 528, 457 ),
	Show Control Panel( 0 ),
	Variables( X( :Column (3) ), Y( :Column (4) ) ),
	Elements( Points( X, Y, Legend( 3 ) )),
		Dispatch(
			"Median 1",
			ScaleBox,
			{Add Ref Line( _LSL1_, "Solid", "Black", "xLSL", 1 ),
			Add Ref Line( _USL2_, "Solid", "Black", "xUSL", 1 )}
		Dispatch(
			"Median 2",
			ScaleBox,
			{Add Ref Line( _LSL2_, "Solid", "Black", "yLSL", 1 ),
			Add Ref Line( _USL2_, "Solid", "Black", "yUSL", 1 )}
second case
xColName =  Column Name( 3 ); show (xColName);
yColName =  Column Name( 4 ); show (yColName);
Graph Builder(
	Size( 528, 457 ),
		Dispatch(
			xColName, //"xColName"
			ScaleBox,
		Dispatch(
			yColName, //"yColName"
			ScaleBox,
When it's too good to be true, it's neither
Re: Add Ref Line () nor working if axes names are supplied from outside.
I would use a better programming structure to accomplish what you are looking for.  The Reference Lines can be directly applied to the chart by modifying the Axis Object(s) in the display output.  See below:
gb = Graph Builder(
	Size( 528, 457 ),
	Elements( Points( X, Y, Legend( 3 ) )));
gbr = report(gb);
gbr[AxisBox(1)] << Add Ref Line( _LSL1_, "Solid", "Black", "xLSL", 1 );
gbr[AxisBox(1)] << Add Ref Line( _USL2_, "Solid", "Black", "xUSL", 1 );
gbr[AxisBox(2)] << Add Ref Line( _LSL2_, "Solid", "Black", "yLSL", 1 );
gbr[AxisBox(2)] << Add Ref Line( _USL2_, "Solid", "Black", "yUSL", 1 );
The details on how to modify the Display Tree output can be found in the Scripting Guide.  All of the messages that can be sent to the display objects are listed with definitions and examples in the Scripting Index.
gb = Graph Builder(
	Size( 528, 457 ),
gbr = report(gb);
