J_Bonnouvrier1
Add Mean to distribution plateform
Dear community,
Regarding the distribution plateforme, I have been asked if it was possible to display the value of the mean of the distribution on the chart?
Thanks and regards,
Jérome
ron_horne
Re: Add Mean to distribution plateform
Hi @J_Bonnouvrier1
could you please give us more information? if you want the numbers on the side of the graph you can follow this picture using the graph builder.
otherwise, if you want it on the axis you can add a reference line by right clicking on the axis>>axis settings.
Best practice is doing this once manually and if needed generalizing the script for future use.
you can see this as an example:
Open( "$SAMPLE_DATA/Big Class.jmp" );
dis = Distribution( Continuous Distribution( Column( :height ), Vertical( 0 ) ), ); reportdis = dis << Report; M = reportdis["Distributions", Number Col Box( 2 )][1]; SD = reportdis["Distributions", Number Col Box( 2 )][2]; dis << SendToReport( Dispatch( {"height"}, "Distrib Histogram", FrameBox, Add Text Annotation( Text( "Mean = " || Char( Round( M, 2 ) ) || " SD = " || Char( Round( SD, 2 ) ), Fixed Size( 0 ), Text Box( {0, 0, 65, 65} ), Filled( 0 ) ) ) ), Dispatch( {"height"}, "1", ScaleBox, {Add Ref Line( M, "Solid", "Medium Dark Red", Char( M ), 1, 1, Label Settings( {Label Color( "Medium Dark Red" ), Label Position( "Inside Above" )} ) )} ) );
Otherwise there are many ways to present the mean in a distrinution, including binning the histogram using different units as in this link: https://community.jmp.com/t5/JMP-Add-Ins/2D-Histograms/ta-p/377945
this addin allows you to use SD as bins so all is focused on the mean.
Let us know if this helps.
ron
statman
I'm not sure if you are asking whether there is an option to display the mean automatically...I know you can always double click on the axis and add any reference line to the plot.  Put the mean in the Value box, select the color, style and size of line and Add.
J_Bonnouvrier1
Thank you for your answer. Actually, yes, I would like the calculated mean value to be automatically displayed on the chart
ron_horne
Hi @J_Bonnouvrier1
ron
J_Bonnouvrier1
Thanks you Ron, I don't have only one but many solutions.
My intuition told me that there is no native option to display it in the distribution plateform and I needed to use a script, but the graph builder option is also an option for reporting only.
Best regards!
Jérôme
