See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Add In limit?
kwmcm
I use lots of AddIns for my scripts, and I just tried to add another, saved, and it's not showing up in my AddIn list.
When I go to View AddIns, I see that it is Italicized, but I'm wondering if there's a limit to how many AddIns are visible?
I have 75 listed, so I'm wondering if that's my limit?
Thanks so much!!
8 REPLIES 8
Re: Add In limit?
Have you gone to
View=>Addins
to see if it is registered?
Re: Add In limit?
You might need to use sub menus. Not sure what the limit might be.
kwmcm
Re: Add In limit?
Any links to help with sub-menus? there are a ton I can group together, just not sure how. Thanks!
kwmcm
Re: Add In limit?
Yep- it's registered!
Re: Add In limit?
That sure makes it a requirement to start adding subcategories in your pull down menus
kwmcm
Re: Add In limit?
How can I do this? I'm not seeing anything. Thanks
Re: Add In limit?
Under
View=>Customize
you can modify the various menu options, including the Addins menu
Jeff_Perkinson
Re: Add In limit?
Look in the Log window to see if there are any messages about trouble adding the menu associated with the Add In.
Also make sure the "Enabled" check box is checked in the View->Add Ins window.
-Jeff
