Actual vs Predicted Residual Plot Apply to which types of fit personality
Hello!
I have been seeing some mentions of an actual Actual vs. predicted residuals plot to help with data analysis. however when analyzing my data though jmp, this plot does not come up for me nor is it an option. The jmp site mentions that this usually pops up by default.
Could this plot be unavailable to me due to my use of the nominal logistic fit
Thierry_S
Re: Actual vs Predicted Residual Plot Apply to which types of fit personality
The Actual versus Predicted plot is only associated with models involving continuous Xs and Y. The confusion matrix in the ordinal logistic model delivers the same concept but for a categorical Y (i.e., Actual versus Predicted).
Best,
TS
Thierry R. Sornasse
Victor_G
Hi @MedianPuppy4982,
Depending on the personality of your linear model with continuous response(s), the "Actual Vs. Predicted" plot may not always appear.
You can make it appear by clicking on the red triangle, go to "Row Diagnostics" and click on "Actual Vs. Predicted plot" : https://www.jmp.com/support/help/en/17.2/#page/jmp/row-diagnostics.shtml#ww694286
For logistic model, as the response is not continuous but categorical, you won't have the same type of plot, but you can display the Confusion matrix showing the predicted classes Vs. Actual classes, available through the red triangle : https://www.jmp.com/support/help/en/17.2/#page/jmp/options-for-nominal-and-ordinal-fits.shtml#ww3151...
You can also make these graph appear by default by going into your JMP menu "Preferences", searching for these two graphs, and check them by default : https://www.jmp.com/support/help/en/17.2/#page/jmp/jmp-preferences.shtml
Victor GUILLER
Scientific Expertise Engineer
L'Oréal - Data & Analytics
