gam1
Accessing summary of fit when By argument is used
I make a summary of fit table by using the script:
dt = Data Table("Big Class Data");
biv = dt << Bivariate(
					Y( :weight ),
					X( :height ),
					Fit Line(),
					//By(:sex),
rpt = biv << Report;
rpt["Bivariate Fit of weight By height?", "Linear Fit", "Summary of Fit",Table Box( 1 )] << Make Combined Data Table;
 However, I don't understand why the same script doesn't work if I apply By (:sex) argument?
I get the following massage:
Can someone explain what I do wrong and how to fix it?
Thank you in advance!
Re: Accessing summary of fit when By argument is used
When you use By you will get a list of references (you can check this by using Show for example). Depending how you build your search for the reference, you might be able to just change from rpt to rpt[1] which is then single item
	Y(:weight),
	X(:height),
	Fit Line(),
	By(:sex),
show(rpt);
rpt[1]["Bivariate Fit of weight By height?", "Linear Fit", "Summary of Fit", Table Box(1)] << Make Combined Data Table;
	Y(:weight),
	X(:height),
	Fit Line(),
	By(:sex),
show(rpt);
