chanson
ANOVA of Dose-Response Curve
I have some basic questions.
I need to create a dose response curve for 3 drugs and 2 controls. How can I use 2-factor ANOVA to compare the drugs and controls? Do I make one of the drugs the dependent variable and a control and another drug as the independent variables? I'm very new to this stuff so I would appreciate some help.
Thanks!
Thierry_S
Re: ANOVA of Dose-Response Curve
I think that I provided some direction relevant to this question in your other post: Setting control as baseline
Thierry R. Sornasse
What do you mean by "compare?"
Also, you have two directions to answer the questions once you decide what comparison makes sense. The first approach is the extract a scalar value, like ED50, You won't be able to apply statistical inference, though, unless you have more than one independent curve for each sample (drug or control). Fit Curve as @Thierry_S suggested provides methods to directly compare parameter estimates or test equivalence. The second approach is to use the entire curve. The Functional Data Explorer will convert each curve into a set of 'functional principle components' that represent the salient features of the curves and can be used as a new response variable. You can them use it with the drug and control categorical variable to compare.
