A bug: Categories changes in local data filter depending on display option
Why do the categories change when changing display option in local data filter???
Re: A bug: Categories changes in local data filter depending on display option
I can see the problem in JMP 16.0, but the bug has been fixed in JMP 16.1 / 16.2.
Hi @Lars_Østergaard - I have not been able to duplicate this in some initial tests.  What version of JMP are you using?  Are you switching the display option with the filter text in place, or are you interactively typing into the filter field in each example?
I am using version 16 and problem is present even when I just search for a simple string in the local data filter.
I will share a modified version of the jmp file.
In graph builder I expected to see both M312V and M312Z but filtering on M312 only gives me M312Z. M312V becomes visible when filtering on M31.
Is this behavior as expected or is it a bug?
Many thanks for looking into this so quickly - I'll try to get the software updated ASAP.
