I am trying to get to the bottom of an odd observation when trying to fit data using a 4PL. In short, when I fit my data I end up with a flat line:
If I do any of the following I end up with a more proper looking fit, and I am sure that other minor changes to the numbers themselves may also fix this bug:
- Change 0.08 to 0.0800000001
- Change 26042 to 26043
- Invert the way the data is within the table (weirdest one to me because it is the same exact numbers)
Here is the resulting fit:
Regardless of whether this is the correct fit to use for this data set, it is strange to see this odd behavior. If there is another explanation other than a bug/glitch and someone can explain that would be amazing!
