I have attached data tables that hopefully are helpful in answering this question! Thank you for your consideration.
I use JMP Genomics and the Correlation and Principal Variance Component Analysis function. Below are the settings I changed for each tab -- if not mentioned, then I used the default settings.
General Tab:
- Input SAS Data set = "PCA Groups Data 1". File is attached.
Experimental Design tab:
- Experimental Design SAS Data Set = "PCA Groups Exp file 1". File is attached.
- Color Variables =Group
- Experimental Factor Variables = Group
- Label Variable = Group
PCA tab:
- Center rows
- Pearson Correlation
@statman , thank you for your suggestions!
1) When I right click on the graph area, I don't see "points" as an option or any option that involved jittering. I see the following: Reset, settings..., Hide Lights Border, Wall Color, Background color, Rows, Use Hardware Acceleration, Show ArcBall. Clicking on Settings allows options for changing the size and color of the points but not to jitter them. Is there another way to access the menu you're talking about?
2) I do include an Experimental Design table that defines each group, as required by the JMP Genomics process, and it yields the result I included an image of. So it doesn't help with the jittering issue, unfortunately.
Thank you all for your consideration.
