Conny_Wang
怎么单独使用变量替换列表里面的值并计算
lsl = 53;
target = 61;
usl = 69;
dataspec = Expr({ LSL( lsl ), USL( usl), Target( target ), Show Limits( 1 )});
dt:data << Set Property( "Spec Limits",Eval(dataspec ));
代码如上,但是始终不生效,规格线无法赋值,请求大家的帮助,感谢!
Re: 怎么单独使用变量替换列表里面的值并计算
You will have to evaluate your values
lowlimit = 53;
targetvalue = 61;
highlimit = 69;
dataspec = EValExpr(
	{LSL(Expr(lowlimit)), USL(Expr(highlimit)), Target(Expr(targetvalue)), Show Limits(1)}
dt:weight << Set Property("Spec Limits", Eval(dataspec));
or you can do eval + evalexpr
lowlimit = 53;
targetvalue = 61;
highlimit = 69;
Eval(Eval Expr(
	Column(dt, "weight") << Set Property(
		"Spec Limits",
		Show Limits(1)}
lowlimit = 53;
targetvalue = 61;
highlimit = 69;
lowlimit = 53;
targetvalue = 61;
highlimit = 69;
Eval(Eval Expr(
		"Spec Limits",
		Show Limits(1)}
Conny_Wang
I have successfully solved this issue by following your method,thanks~
