To get the script that will generate the Partition, go to the red triangle and select
Save Script=>To Script Window
It will provide you with the following script
Partition(
Y( :weight ),
X( :age, :sex, :height ),
Split History( 1 ),
Informative Missing( 1 ),
Initial Splits( :height < 65, {:height < 60, {}, {:age == {12, 13}}} ),
Dispatch( {}, "Partition Report", FrameBox, {Frame Size( 480, 82 )} ),
Dispatch( {}, "Split History", OutlineBox, {Close( 1 )} )
You can reference this window with
p=current report();
