lala
Level IX
如何引用已运行平台的输出报告和生成它的可执行对象?
大家好!
我打开这个文件、用手动进行了决策树模块的操作。
在这时才在脚本中定义这个决策树的窗口、要怎样编写代码?谢谢!
Re: 如何在脚本中临时指定当时的窗口?
Is this what you are looking for?
Partition(
	Y( :weight ),
	X( :age, :sex, :height ),
	Informative Missing( 1 ),
	Initial Splits( :height < 65, {:height < 60, {}, {:age == {12, 13}, {}, {:age == {14}}}} ),
	SendToReport( Dispatch( {}, "Partition Report", FrameBox, {Frame Size( 480, 102 )} ) )
p = Current Report();
x = p[Outline Box( 1 )] << get scriptable object();
x << save prediction formula;
x << save leaf label formula;
p << close window;
10 REPLIES 10
To get the script that will generate the Partition, go to the red triangle and select
     Save Script=>To Script Window
It will provide you with the following script
Partition(
	Y( :weight ),
	Split History( 1 ),
	Initial Splits( :height < 65, {:height < 60, {}, {:age == {12, 13}}} ),
		Dispatch( {}, "Partition Report", FrameBox, {Frame Size( 480, 82 )} ),
		Dispatch( {}, "Split History", OutlineBox, {Close( 1 )} )
You can reference this window with
p=current report();
lala
Level IX
Thank Jim!
I see, the original P is shown as successful.
I've tried P before.
p=current report();
Think it's not gonna work.
You can reference either the Current Report or the Window directly and specify the window size.  Here is a working example
Partition(
	Y( :weight ),
Wait( 5 );
x = Current Report();
x << Set Window Size( 1200, 1200 );
Wait( 5 );
p = Window( "big class - Partition of weight" );
p << Set Window Size( 800, 1200 );
lala
Level IX
是的、执行决策树的代码这样编写。
我不编写决策树的执行代码是为了进行试验、看见效果适合才将决策树后面的操作用代码完成。
谢谢!
Are you looking to adjust the size of the Data Table Window?
//This message applies to all display box objects
w = Open( "$SAMPLE_DATA/Big Class.jmp" );
w << Set Window Size( 800, 1200 );
lala
Level IX
我主要需要分割后的统计全部自动进行。
分割过程可以自己手动逐一观察
lala
Level IX
p << save prediction formula;
p << save leaf label formula;
p << Close Window;
Partition(
	Y( :weight ),
p << close window;
pmroz
Here's another approach that doesn't require getting the report.
prt = dt << Partition(
	Y( :weight ),
prt << save prediction formula;
prt << save leaf label formula;
