lala
Level VIII
一个另类的问题: 请问JMP是否会出品 图像识别的深度学习模块?
首先感谢功能强大的JMP!
现在我连python也不使用了、完全只使用JMP。
可能这已经超出统计的范畴。
谢谢专家!
P_Bartell
Level VIII
Re: 一个另类的问题: 请问JMP是否会出品 图像识别的深度学习模块?
If you want this type of capability in JMP I suggest creating a JMP Wish List entry here in the Community. JMP product management and developers take very seriously input from users...and in the Wish List there is an option for other Community members to vote on the idea...the more votes your idea gets...the more likely it will make it's way into the product.
Of course SAS is capable of deep learning and image recognition. In fact, that task would be better handled by Viya as that handles large computing and data-intensive problems
Dan Obermiller
Hello @lala,
I agree with @P_Bartell on making a Wish List request.
One question for you is how deep is deep?  JMP Pro currently offers a 2 layer approach with as many hidden nodes as you want to add in each layer and you have 3 activation functions to choose from for those layers and hidden nodes.
On top of that you can use boosting that fits an additive sequence of models for the residuals scaled by the learning rate.  Basically you can make this number as big as you want and JMP will use only as many boosting steps as it needs to give the best fit.  Just remember the bigger the number the longer it will take to fit the model.
There is also built in cross-validation or you can use three level validation to help avoid overfitting of the data.
Hope this is helpful.
Kind regards,
Bill
lala
Level VIII
回复: 一个另类的问题: 请问JMP是否会出品 图像识别的深度学习模块?
非常感谢专家们的解答。
确实深度学习是比较耗时的。期待中。
