Ted
Ted
Сompeting analysis
Is there any way to perform a competing analysis in JMP?
Phil_Kay
Re: Cumulative incidence function in JMP?
I think you should find the capabilities for this as part of JMP's Reliability and Survival methods. Have a look in Help > Books > Reliability and Survival Methods. In particular Life Distributions > Competing Cause Report might be what you are looking for.
The "Blenders" sample data file in JMP has an example of competing cause analysis.
I hope this helps.
Regards,
Phil
Phil_Kay
I hope this helps.
Regards,
Phil
Ted
Ted
Thank you!
