Clay Barker, PhD, JMP Senior Research Statistician Developer, SAS
The Generalized Regression platform in JMP® Pro helps you build better predictive models by using penalized regression techniques. But, with a little extra care, you can also use the platform to do some things you might not expect, like screening your data set for outliers and looking for changepoints in your process. We will look at some innovative uses of the platform. Examples will include ranking baseball teams and analyzing the reception of several popular television shows.
