Having Fun with SPC Using JMP® Scripting Language
Wenyu Su, Jeff Sweeney, and Wayne Zirk, The Dow Chemical Company
Statistical Process Control (SPC) is widely used at The Dow Chemical Company to investigate the process stability. JMP scripts are utilized to automate the statistical monitoring process. JMP scripts significantly reduce the data analysis time.
