Chrismtoy
Staff (Retired)
Automating Process Capability Analysis Reporting for Multi-Product Parameter Sets
Thomas D. Steinmetz and Byron A. Wingerd, PhD, Merck Manufacturing Division
Conceptually, the procedures for reporting process capability metrics for individual process parameters or even groups of process parameters is relatively simple using the JMP Capability Analysis reports. When a large number of parameters, with a mixture of normal and nonnormally distributed data and changing specifications sets, require a cross product capability analysis, the reporting can become more complex and tedious. We have developed a scripted reporting method that allows a bulk data dump to be merged with an easily updated specifications table that includes definitions of the parameter distributions. The resulting reports are interactively tied, to drill down, control chart, reports which display individual data points. This method has been useful for generating multi-product and single product comparisons, and provides customers of the reports the opportunity to explore process data with very little training in the use of the JMP software.
Comments
psunkari
Hi,
Its very interseting to see the document, I am looking for similar one if it is possible can you share me the script.
Regards
Phani
Article Labels
Article Tags
Contributors
