  • See how to use the JMP Marketplace – Free tools to expand JMP capabilities. Register. July 10, 2 pm US Eastern Time.
Design of Experiments Club Discussions
Recording Experimenters' Club Q1 2026
Video 1: JMP's DOE platform: A new addition to the artist's toolkit
(view in My Videos)
Read the blog from @BillFish828 here: https://community.jmp.com/t5/JMP-Blog/JMP-s-DOE-platform-A-new-addition-to-the-artist-s-toolkit/ba-p...
Question: What is the difference between Taguchi design and Orthogonal array.
MOLS is a balanced fractional factorial design matrix that ensures independence between factors, whereas a Taguchi Design utilizes these matrices to optimize the S-N ratio mean response enhancing robustness
Video 2:  Why randomize when n=1
(view in My Videos)
Comment: My point was less about the trend, it was more about a not identifiable effect, so something you really did not know before the experiment. And my recommendation is to start with as many influences you can think of, even some far fetched influences, to select the factors from, and then observe any not included factor if possible.
Video 3: In-depth analysis of DOE's such as Response Surfaces (RS)
(view in My Videos)
1 REPLY 1
Victor_G
Re: Recording Experimenters' Club Q1 2026
Thanks for the recordings @maria_astals !
On the topic of randomization, I don't totally agree with the purpose of randomization as avoiding time trend in the response. Randomization is there to avoid any bias in the experiment resulting from the influence of some extraneous unknown and uncontrollable factors that may affect the experiment. It is used to avoid confounding between treatment effects and other unknown effects (spurious correlations).
Depending on how the experiments are randomized, the design robustness against time may be more or less effective. Some better options (depending on how known and controllable the nuisance factors are) are :
  • Recording the actual run order and use it as a covariate in the model to evaluate its statistical significance and practical importance (again a "post-mortem" analysis to evaluate if order of the run may have an impact) for a known and uncontrollable nuisance factor,
  • Using blocking as @statman said, to balance factors levels as homogeneously as possible between blocks, in order to reduce or even cancel out the known and controllable nuisance effect(s). Blocking allocates similar runs in different blocks/groups of runs : different operators, equipment/machines, possible difference between days, between weeks, etc...
  • Design upfront the DoE by taking into consideration this possible time dependance using time as covariate, to balance the factors levels across time. @bradleyjones wrote a really good article on how to create a design robust to time-trend: How to create an experiment design that is robust to a linear time trend
    You can see an application here: Covariates in defined order in custom design
    The situation of using time as covariate to create a robust time-trend design is explained in the book "Optimal Designs of Experiments : A Case Study Approach" from Peter GOOS and Bradley JONES (Chapter 9: Experimental Design in the presence of covariates).
I wouldn't worry too much about one data point showing outlier/anomaly values, DoE are by design less sensitive to few outlier values than OFAT or other similar methods.
Looking forward to joining you next time !
Victor GUILLER
