Video 1: Practical relevance of Bayesian Optimization for chemical/formulation
Overview on when to use what:
- DSD: many continuous factors, few expected to matter, no constraints. It is an early stage tool.
- Custom Design: mixtures, constraints, categorical factors, or when you need an interpretable model and a design space for a regulatory filing. This is the workhorse for formulation.
- Bayesian Optimization: the surface is strongly nonlinear, runs are expensive, and the goal is a good answer more than an explanation.
They also combine well. A common sequence is to screen with a DSD or a small custom design, then either augment for a response surface model or hand the same data to Bayesian Optimization as its starting set. The DSD seeded approach was the one reported on the JMP Community to converge faster than starting from space filling runs.
Do you have any examples of utilizing Bayesian Optimisation in a two-stage DOE process? I know how to do this in a multi-stage DOE process, but how is this effectively down with Bayesian Optimisation?
Some resources:
Video 2:
Part 1: If you experience, low Rsq, and lacking ideas to find more relevant factors how to move forward?
Part 2: if your response has large variation, can this be handled better?
Part 3: If your Response is Pass/Fail or Categorical, how can you handle this?
Comments
- Debug/assess why the performance is low: low experimental space coverage, high uncertainty, ... Example: Re: Problem to find optimal settings for a mixture with Bayesian Optimisation
- There may be more evaluation to do on the measurement process (MSA) part
- Maybe you need a response proxy, like probability to pass/fail based on a logistic model. But I think the BO platform can handle categorical responses natively
Starter with DOE, then BO, or use BO for the analysis of Space-Filling design and "design augmentation" besides other analysis methods
Interesting study to use DSD instead of LHS for starting BO - Combining DoE with Bayesian Optimization: Practical Bayesian Optimization in the Fab (2026-US-30MP-2920)
From Victor: Maybe categorize/bin your data ?
You seem to have a bimodal distribution with cluster around low values and cluster around high values. And do you have replicates or runs repetition to visualize/assess the reproducibility of your measurement (through repetitions) and/or the full experimentation process (through replicates)?
From Scott: Group Avg as one response and Group Variation as another response in a model might get you in the ballpark to make estimates…optimize Avg while Minimizing Variation.
From Victor: Or use the data as it is, and model response mean and response variance through Loglinear Variance Models ?
Are your experiments independant ? Looking at the residual pattern it doesn't look like. Can you add an experiment number run as a factor (that could work as a proxy for your membrane usage) ?
And you can also model curves without FDE ! Using platforms like Fit Curve or others, trying to find a curve family that match your experiments and modeling the curve parameters with your DoE factors, then re-construct the curves based on the predicted parameters from the DoE model.
From Chandra: Functional Data Explorer (FDE) in JMP Pro treats each whole curve as one observation. Typical curves are dissolution profiles, spectra, chromatograms, and batch or sensor traces. You find it under Analyze > Specialized Modeling > Functional Data Explorer, and is JMP Pro feature. https://www.jmp.com/support/help/en/18.0/jmp/functional-data-explorer.shtml
