Design of Experiments Club Discussions
SteveCz
Number of factor levels in I-Optimal design
For an RSM I-Optimal design created in Custom Design, is there a way to control the number of factor levels?
Here's an example.
  • I create an I-Optimal RSM design with 5 continuous factors and a few replicates and I get a plan with levels -1, 0 and 1 only
  • However, I have a keen interest in the behavior of one of the factors and thus prefer to have 5 different levels.  A plan with -1, 0, 1 and two other levels (as determined by the design generator, not by me) would help me understand that factor better by filling in the space between -1 and 1 with 3 other levels, rather than only one.
Any sage advice would be much appreciated.
Steve
It ain't what you don't know that gets you in trouble, it's what you know for sure that just ain't so. (Attributed to Mark Twain)
Victor_G
Re: Number of factor levels in I-Optimal design
Hi @SteveCz,
I see at least two options to get the desired number of levels in your DoE by using Custom design platform :
  • Either you specify in the model panel some higher order effects for your factors : for example, specifying up to 4th order polynomial terms in the model for X1 will create a design with 5 levels for X1,
  • Or you could create a design with discrete numeric factors in the Custom Design to "enforce" the number of levels and specific levels you want to include in your design, and switch back the design role of the factors to "continuous" once the datatable is created.
These are the options I already recommended in these discussions :
Inquiry about Experimental Design with JMP force levels in DoE
Hope you'll find a satisfying option for your needs,
Victor GUILLER
Victor_G
Hi @SteveCz,
Victor GUILLER
SteveCz
Hello Victor,
Thanks for the two suggestions.  I tried both of the methods and they worked as you described without a major impact on power, prediction variance and the correlation coefficients from the Color Map.   All up, a very good solution.  Thank you!
Steve
