Created:
Sep 8, 2023 09:51 AM
| Last Modified: May 23, 2024 6:37 AM
High correlation in predictor variables can harm your linear regression model. This problem is called collinearity or multi-collinearity. The first video is an overview of collinearity, how to understand it, how to detect it, how it is related to the VIF (Variance Inflation Factor) shown in JMP reports and how to interpret VIF. The second video shows how to use Principal Components Analysis to build models that accurately account for collinearity. The attached JMP Journal gives you the data used in the videos, so you can try the techniques.
Identifying and Understanding the Impact of Collinearity
Video Player is loading.
Current Time 0:00
Duration 0:00
Loaded: 0%
0:00
Stream Type LIVE
Remaining Time -0:00
1x
Chapters
descriptions off, selected
captions settings, opens captions settings dialog
captions off, selected
en (Main), selected
This is a modal window.
Beginning of dialog window. Escape will cancel and close the window.
End of dialog window.
This is a modal window. This modal can be closed by pressing the Escape key or activating the close button.
@hogi, the scale of the axes on a leverage plot is set to the data scale after the plot is created. First, find the residuals for both models, then add the mean, then scale the axes to the data. For details, see Predictum's excellent video stored at Leverage Plots 2.mp4 on Vimeo. You might also be interested in the first video of the two-part series at Leverage Plots 1 on Vimeo.
