  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
Community Wish List
Let us know how you think the JMP User Community could be improved. Enter your suggestion or comment and vote on other suggestions by giving it a kudos. We want your feedback!
Make posts more robust to row changes when using different styles
When posts get longer and longer and you have to make modifications to your post (adding <JSL> or spoiler tags), the posts might end up with massive amount of excessive white space. Example post: https://community.jmp.com/t5/Discussions/Use-expr-to-replace-variable-column-names-in-a-formula/m-p/...
this seems to be because the editor we use to write posts leaves extra white space to the html code
To fix these "easily" I basically have to open the html and fix it there.
What I would like is to the post editor be more robust against these as it would result in much better posting experience and cleaner posts in community.
