Community Wish List
Let us know how you think the JMP User Community could be improved. Enter your suggestion or comment and vote on other suggestions by giving it a kudos. We want your feedback!
Make posts more robust to row changes when using different styles
When posts get longer and longer and you have to make modifications to your post (adding <JSL> or spoiler tags), the posts might end up with massive amount of excessive white space. Example post: https://community.jmp.com/t5/Discussions/Use-expr-to-replace-variable-column-names-in-a-formula/m-p/...
this seems to be because the editor we use to write posts leaves extra white space to the html code
To fix these "easily" I basically have to open the html and fix it there.
What I would like is to the post editor be more robust against these as it would result in much better posting experience and cleaner posts in community.
