Browse apps to extend the software in the new JMP Marketplace
Ryan_Gilmore
Goodbye SAS Profile. Hello My JMP ID.
The SAS Profile has been used for years to sign into the JMP User Community. On Wednesday, November 28, 2023, the Community will begin using My JMP ID instead of the SAS Profile.
So, what does this mean? When you click Sign In, you'll be directed to the My JMP login page and will no longer use a password to sign in. Instead, you will be prompted to enter a verification code sent to your email address.
If you no longer have access to the email address you use to sign in to the Community, we recommend you change it (Changing your Profile Information ) before the transition to My JMP ID.
Remember, when you click Sign In, instead of seeing this,
You will now see this, where you'll enter your email address:
The first time you sign in using your My JMP ID, you will be prompted to enter your first name, last name, and email address,
The next step is to verify your identity. An email will be sent to the email address entered with a verification code.
And accept the terms and conditions.
After you click Continue, you will be redirected to the JMP User Community. If you are an existing Community user and are prompted to enter a Community username, please contact our support team at support@jmp.com.
Once you have signed up for your My JMP ID, you will no longer use a password to sign in. Instead, you will be prompted to enter a verification code sent to your email address:
Here is a sample email with the verification code:
If you have any issues, please contact our support team at support@jmp.com.
Last Modified: Nov 21, 2023 11:02 AM
Comments
Stefan
Level III
Is there any way to bypass this or stay logged in on non-shared computers?
Ryan_Gilmore
Community Manager
Hi @Stefan. Once signed in to the Community, you should not have to go thru the entire sign in process again for several days unless cookies are disallowed or have been removed. However, at some point, yes, you will need to enter a verification code as there is no method for bypassing that.
Stefan
Level III
Hi, tried for the last week, I have to log in daily, it's not a major inconvenient, but you could have an option of "keep logged in on this computer or something". Cheers
hogi
Level XII
Maybe related to your browser/ cookie settings - did you try it on another device? With another browser?
