Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
EMDLEB
Shift multiple rows selection 1 up JSL
This is my first post!
Is there a way to shift the rows selection 1 up in JSL?
Example: selected rows are 5,9,10
shift selection up will select rows 4,8,9
This is done is VS as follows:
Sub moveselection()
Selection.Offset(1, 0).Select
End Sub
Re: Shift multiple rows selection 1 up JSL
This will require some additional error check for 0 row which depends how you want to handle it (do you want to loop it around for example):
dt = New Table("Untitled",
	Add Rows(10),
	New Column("Column 1",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([., ., ., ., ., ., ., ., ., .])
	Set Row States([0, 0, 0, 0, 1, 0, 0, 0, 1, 1])
wait(1);
sel_rows = dt << Get Selected Rows;
dt << Clear Select;
dt << Select Rows(sel_rows - 1);
Or you could possibly use row states.
Edit:
With row states it could be something like this (only works this way if Selection/no state are only row states):
dt << Set Row States((dt << Get Row States)[2::NRows(dt)] |/ [0]);
