Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
Selection of discussion with many entries does not go to last entry
Using Chrome browser under Window's 7 and under Window's 10, I am not being sent to the last discussion entry for discussions with so many entries, they are divided into multiple pages.  The example discussion is: Probit Analysis & Fit Testing.  Currently, there are 3 pages available for selection.  Under Window's 7, my browser consistantly brings up page 2 when I select the discussion.  Under Window's 10, it brings up page 1.  I assume it should be brining up the last entry on page 3
Jeff_Perkinson
Re: Selection of discussion with many entries does not go to last entry
I think what you're seeing is the effect of being logged in or not.
When you're logged in the behavior is controlled by your Preferences.
The last item there is set on by default and will jump you to the first unread post in a topic.
If you're not logged in I think it will always start on the first page of a topic.
Let me know if this doesn't explain the behavior you're seeing.
-Jeff
Jeff_Perkinson
-Jeff
OK, thanks
