Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
Propensity Score matching
Is it possible to generate Kaplan–Meier survival curves for the two matched groups after propensity score matching using JMP Student Edition 19?
According to information on the JMP Community website, propensity score matching is available starting from JMP Student Edition 19, and I was able to successfully complete the propensity score matching. However, I could not determine how to compare survival between the two matched groups (i.e., how to create Kaplan–Meier curves based on the matched pairs).
I would greatly appreciate your guidance on this matter. In addition, if this type of survival analysis is possible in JMP Pro but not in the Student Edition, I would be grateful if you could also clarify that point.
JMP Student Edition19では傾向スコアマッチング後に、マッチングさせた2群でのカプランマイヤー曲線を作成することは可能でしょうか?
JMP Communityで調べますと、JMP Student Edition 19から傾向スコアマッチング可能とあり、傾向スコアマッチングは完了したのですが、マッチさせた2群での生存率の比較(カプランマイヤー曲線)の仕方がわかりませんでした。
ご教授頂けますと幸いです。もし、Student Editionでなく、JMP Proであれば解析可能などもわかりましたら、教えてください。
Re: Propensity Score matching
hi, and welcome to the community!
I just released this from the spam trap, but you probably want to re-post your question in https://community.jmp.com/t5/Discussions/bd-p/discussions, "Discussions" , at the top left of the menu bar. I think this group is not monitored much and is for discussions about the community rather than discussions about the software.
 (No idea what made it go into the spam trap...)
Thank you for replying.
I try to send the comment in "Discussions" , at the top left of the menu bar.
