Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
David_Burnham
Navigation
Probably me, but I keep experiencing cognitive dissonance when I look at the menus.  Attached is a screenshot of where I am (or where I was when I took the screenshot).  From the screenshot I think I am in JMP Blogs.  I think my confusion is with the appearance File Exchange>Other Communities>JMP Blogs. This is standard notation for a "bread crumb path", whereas you are using the ">" symbol to indicate a dropdown menu.
-Dave
JonesieAtJMP
Re: Navigation
Styles and icons updated for navigation issues. @David_Burnham indicated that this is an improvement in another post. Marking as solved.
A JMP Community Admin
David_Burnham
Re: Navigation
Duh.  Here is the attached screenshot
-Dave
Jeff_Perkinson
Re: Navigation
Good point. I'll ask our designers, @JonesieAtJMP@ian_jmp and @jonathan_bryant to take a look at this.
-Jeff
Jeff_Perkinson
Re: Navigation
While they are looking at that, perhaps they can also look at why there's an extra space added after the @ mentions. I didn't put that in there.
-Jeff
JonesieAtJMP
Re: Navigation
