  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
txnelson
Go to Solution Link just goes to the bottom of the discussion
It appears that the "Go to Solution" branch in a discussion that has been marked as "Solved" just goes to the bottom of the discussion page.  If additional replys have been added to the discussion, it is those replies the user sees and not the solution
Jim
1 ACCEPTED SOLUTION
Accepted Solutions
Jeff_Perkinson
Re: Go to Solution Link just goes to the bottom of the discussion
Thanks, @txnelson.
This post is a good example of the problem. Hopefully, @IanAtJMP, can fix track this one down.
-Jeff
4 REPLIES 4
Jeff_Perkinson
Thanks, @txnelson.
-Jeff
IanAtJMP
Level VI
Gave your reply the solution. Clicking "go to solution" takes me to this reply on Chrome/Mac.
Community Manager, Senior Digital Designer at JMP
IanAtJMP
Level VI
Hi @txnelson Jim,
I'll need that info on this one as well.
Can you give me your platform, OS, browser, and browser version, as well as a link to the discussion(s) in which you've seen this problem?
Thanks
txnelson
Windows 10, Edge and Chrome
Regarding change in data format
Jim
