Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
cchueng
Level III
Extract String which has positive and negtive numbers
Hi,
I have a table1.jmp as atteched. How do I extract the X and Y as circled in the red box? The X and Y values can sometimes be negative. For example, the XY values from the 1st row is -280,-396. The XY values from the 2nd row is 284,-228.
2 REPLIES 2
cchueng
Level III
Re: Extract String which has positive and negtive numbers
This is a tough one. Any wise advice?
txnelson
Here are the formulas that will do what you want
// For the X value
Num( Substitute( Word( 5, Substitute( :Fname, "--", "-&" ), "-" ), "&", "-" ) )
// For the Y value
Num( Substitute( Word( 6, Substitute( :Fname, "--", "-&" ), "-" ), "&", "-" ) )
Jim
