Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
Discussion Item responded to, now shows up as UnRead
After responding to a member's entry, the entry is now displayed to me as UnRead, even though, I had just read it and responded to it.  Is this an intentional change?
9 REPLIES 9
Re: Discussion Item responded to, now shows up as UnRead
Same happening to me. Hopefully it is not an intentional change and if it is, I hope it can be disabled from Settings at some point.
Ryan_Gilmore
I'll investigate and let you know what I find.
thank you
Ryan_Gilmore
This has been acknowledged as a bug by the platform vendor. No estimate on when it might be fixed.
Ryan_Gilmore
@txnelson , the platform was recently upgraded which contains a fix for the unread issue. If you are still having problems, please let me know. Thanks.
Thank you
I am still seeing the issue.  Tonight I opened a members discussion, and wrote a response to it.  I then clicked on the Reply button.  The entry remains open, as expected.  I then clicked on the Discussion button to take me back to the Discussions listing   The entry is highlighted.  It should not be, since I was just viewing and changing it.
Ryan_Gilmore
Hi @txnelson . I see the same. It does appear to work if you view it only. I'll open a case with support. Thanks.
Thank you
