Central Ohio Discussions
tbidwell
Files from COJUG meeting on 5 December 2024 at Alkermes
The speakers from the meeting will post their files here under this topic.
tbidwell
Re: Files from COJUG meeting on 5 December 2024 at Alkermes
I have attached my JMP project which contains all of the JMP tables, journal, pdfs and scripts that I used for my talk on adding the Event Handler to a Column as a method to link to documents to enhance your graphs and analyses.
beeker_g
Thank you for organizing and Gwen and all the folks at Alkermes for hosting. Attached is the JMP file with the information on Text Analysis and Structured Data analysis for Consumer Goods.
Cheers!
drdrf
Here is my presentation on Mixture DOEs with independent variables.  Don't hesitate to contact me if there are any questions.
lee_becker
Attached is a close match in Powerpoint to the JMP Journal I used for my talk on Parallel Plots.  The recording from Discovery is here: https://community.jmp.com/t5/Abstracts/Parallel-Plots-for-Visual-Configuration-Management-of-Model/e...
