I have attached my JMP project which contains all of the JMP tables, journal, pdfs and scripts that I used for my talk on adding the Event Handler to a Column as a method to link to documents to enhance your graphs and analyses.
Sprucing up your JMP charts w event handler.jmpprj
Thank you for organizing and Gwen and all the folks at Alkermes for hosting. Attached is the JMP file with the information on Text Analysis and Structured Data analysis for Consumer Goods.
